.26 picco max
Kyleb
Just thought I'd throw up some pics and specs of a maxx I recently finished. It's a 4910 pro .15. I kept the stock chassis length and width. It's a wheelie machine
Powerhouse
-.26 picco red dot. Modded by AB mods
-OFNA 086 BB pipe and BB header
Drivetrain
- RRP slipper
-RRP transmission gears
-70 mm UE titanium dogbone with 57mm front bone
-MIP steel axles
Other
-FLM towers
-GH bulkheads
-rpm bumper
-wing and wingmount
- UE supershocks
-Traxxas aluminum chassis brace
-direct pull throttle
- proline Chevy body
-OFNA fuel tank
-hump pack with Traxxas switch
I gutted a servo case and mounted the switch in it.
Let me
Know what you think.
Nice! hurry up and put a set of ceramics in that engine.
There's nothing wrong with the stock ones
This truck will be getting a predator chassis by the end of the month :)
I had this in the truck below, once I put the ERCM BB pipe
On it became easier to tune and the carb quit leaking. I put approx 1 gallon on this engine. Nice and broken in now.
I don't like the pipe in this pic it looks hand made like someone welded the 2 half's together.... But other than that Rig looks good....
Its all a matter of opinion thats y robin makes polished pipes also. That ones just unpolished bc some people like the craftmanship of it and plus it doesn't look as rough when it gets scratched up.
I like the raw weld look myself. Your right it shows the craftsmanship involved in the pipes.
---------- Post added at 10:17 AM ---------- Previous post was at 10:14 AM ----------
Also Kyleb, these piccos are notorious for leaky front bearing seals but usually around gallon 3. I just rebuilt mine using boca HP ceramics and went ahead with new sleeve/piston while i could afford it. She still ran fine with the seal leaking. It didnt cause any tuning issues with me but just got tired of cleaning up the mess after running it. Now shes all dry and running strong as ever. No more leaks anywhere.
anyone havin any issues with the carb slide sticking? Or is it just something goin on with this one?
Had that issue on the my revo , took ages to get the right angle you will need to swivel the carb and adjust the arm off the carb until it dont bind
