I have the Omega 21 sport buggy engine (OMAP202). I have broken it in and I almost have a gallon (trinity mhp 20%) through it.
It seems to be really sputtery (loading up) mid throttle. It will idle all day long and once it opens up after feathering the throttle, it takes off like a bat out of hell. But, if I don't lay into the throttle nice and easy past the 1/2 mark, it seems to load up and sputter pretty bad. If I hold it FWO for about 5-10 seconds, it clears out and takes off. If I go from idle to 1/2 throttle quickly, it flips my maxx onto it's roof. But there's a spot in the 1/2-3/4 throttle that is still weird.
I have fooled with the needles, both high and low and it still does it. If I lean out the top, it seems to do it less, but then the temps creep up and it acts like it's about to flame out. If I lean out the low, it wants to heat up on me but does it just the same.
I try to run my engines between 190 and 230. This has served me well in the past on the past 5 engines I've owned. But, the Omega is a new animal to me and I'm not sure what I'm missing. As it's running right now, the normal temp varies between 190 and 210. And like I said, if I'm easy on the throttle, there's a ton of power in this engine.
It did have the loading up feel to it while I was breaking it in and it seems to be getting progressivly better the more fuel I run through it. So, I'm checking to see if anyone else has run into this scenario, if so, what did you do to help?
I have already taken the engine apart and siliconed the backplate and carb. Did that before I installed it. Also, I changed out the glow plug twice to make sure it wasn't that.
Thanks.
Thanks.
