spee-d
what is the best 2 cycle oil to use in the baja? what is the ratio? still waiting for my kit.
whatever you get, make sure its synthetic. the stuff you run in your weed wacker wont cut it. it will work, but the fade in performance is very slow tank after tank so you wont realize how much it sucks. the cheep stuff just wont protect your ring and bearings like you want. the BEST stuff is whatever they have at the motor cycle/atv shop. i have used klotz and now use caster927 race blend. if you use a really good oil you can lean out your fuel mix. I'm running 38:1 with good resoults. but i also change rings about every 5 gallons, not from failure, but to keep it at peak performance
thats cool. you can use whatever anybody wonts its oil and i dont think any of us are winning any races..BUT.. why not use the best. it only cost $6. and that will last many gallons. those oils may work great in your weed wacker and your rc. but echo mills have governers on them. they max out at 10,000 rpm's. we scream at close to 18k. and we put more stress on our mills then i would ever put my weed wacker thru. what works and whats best are 2 diffrent things. but echo oil probly works fine. its not synthetic, but it works..Echo engines (weed whackers) are essentially the same as RC engines. They are made by the Kioritz Corporation which also makes Zenoah engines, which is why I trust Echo oil.
I just use a marine grade oil....
I just buy two of the Echo (or Husqvarna, which is what Lowes carries) 50:1 bottles and mix them both in with a gallon of gas. The final ratio comes out right around 24:1. (two 2.6 bottles of oil = 5.2 ounces, so 128/5.2 = 24.6)
hey cup. i would give it to my neighbor. it takes awhile for me to go thru a gallon.. as far as where to get it. my atv shop was out of klotz($15) so the owner gave me the castor927 wich is as he stated "just as good as klotz." alot of the mx racers use it. my shop sells it for $7 and thes guys have it for $9. just swing into your local atv shop and get whatever good stuff they have as long as its synthetic. those guys mostly only carry good stuff anyway. and for better punch try leaning out your mix. its safe to run 32:1.. i think my 38:1 is pushing it but so is running 33%nitro, right?I stand corrected.
My problem now is that I've got a gallon of 25:1 Husqvarna gas that won't run in anything but my Baja. So should it be ok to run it for just this gallon and then switch to synthetic?onder2: If not I think my neighbor might be able to find a use for it since he's got about 20 2-stroke engines (lawn service).
yup youll want to go with the castol 927
no, but you foul out more plugs and flood easier running too rich if your talking about needle settings rich.
if you mean too much oil, no, but I've heard from some it robs performance but others say it adds cuz the ratio is leaner due to less gas in the mix, but the more oils protects it. personally i m at 25:1 to 32:1
