2.5 Engine problems!!
Austin
RCNT Basher
Georgia
Bashing
Ok so, As most of you know I have a t-maxx 2.5 and it had some previous "clicking" issues, which we agreed were from the diff, which i replaced both of the diff's and i'm pretty sure the problem is gone, but now its the main problem that i've been having but haven't wanted to face.. my engine. So I can turn it on no problem what-so-ever and it runs, but only for a little while, when I turn it on I have to hit the gas and I can't let it idle because if I let it idle, It cuts off on me. The idling problem is one of the problems, the other is that I can run the truck and it runs fine but it will only run for a short moment (about 1 min. maybe less) and then it cuts off by itself. I'm clueless on what it could be :( Hopefully the pros on RCnitroTalk can help!! :D
EDIT: Also sometimes when it cuts off, it might not crank back, so I let it sit for about 10 mins then it cranks again, and By the way I can never get the temps very high on the fact that I can't run it for long at all, I get temps to about 170 (max) and that's it, I can't get it higher, I'm pretty sure I'm running not too rich and not too lean but not completely sure! Thanks for any help!!
gregM784
RCNT Rookie
Sacramento
Racing
Austin, it sounds way lean. Have you checked the needle settings? 4 turns out on the main is WAY rich, give it a try. I run mine about 3.75 turns out. Idle screw screwy? Should be flush with the inner step on the slide.
Austin
RCNT Basher
Georgia
Bashing
To tell the truth bro, I can't tell you a thing about where the truck is at on the needle settings, lately I've been putting it richer and richer but I just wasn't really seeing any results so I quit that, and i never got it that rich anyway, at least I really don't think. I've had the truck since '03, and I had it in storage 2-3 years and I brought it out and fixed it up realllll nice, but It just refuses to run right, I'm also messing with the idle screw here and there, I'll try making it alot richer tomorrow and let you know how it goes, Thanks for the help, appreciate it alot :)
olds97_lss
RCNT VIP
Dekalb, IL
Bashing
It may benifit you greatly to take the carb apart and soak/clean it really well. When they sit that long, the oil in the fuel remains on the parts and creates a really sticky coating that can clog the needles and whatnot.
Just sounds like your fighting a clogged carb.
Your fuel tank may also be a bit clogged up. The stone filter in it does the same thing as the carb if it sits that long. Try letting DA set in the tank for an hour or so with the stone filter completely submerged. Then install a long piece of fuel line on the line to the carb and blow/suck on it (I know... keep laughter to a minimum) so as to work the gel out of the stone filter.
Either a clogged needle or filter will cause it to be permanently lean regardless how "rich" your setting the needles.
Austin
RCNT Basher
Georgia
Bashing
ok olds, I'll see about doing that, and by the way, what's DA? and by the way, Counter-clockwise is richer right?
olds97_lss
RCNT VIP
Dekalb, IL
Bashing
DA = Denatured Alcohol - can be found at hardware stores near paint thinner and mineral spirits. Relatively cheap, but doesn't have water in it like rubbing alcohol which can cause rust.
You can get little spray bottles at walmart in the toothbrush/soap area. That's what I use since the can DA comes in is an awkward can to use for anything.
Correct, CCW = richer
Tmaxx96
Gone - bye bye.
Willington,CT
Bashing, Racing
out of my luck it would be the piston cause if the balance is off of a good piston that will do it to check the piston and see if its cracked or brock at the bottom if it is replace it and it will run fine
Metalhead Matt
RCNT VIP
Northeast Iowa
Bashing
Take the head off. Don't even worry about that. Very unlikely to be the problem. Clean everything real good as stated above and if that don't work, check for air leaks. Be sure and use fresh fuel.
Austin
RCNT Basher
Georgia
Bashing
Well I just broke my carb, lol, so I'm simply buying a new one and that should solve my problem right? or do I still need to soak the fuel tank in DA?
Rolex
Hoof Hearted
Staff member
Military Veteran
In my recliner
Bashing, Flying
Well, start by installing the new carb. Set it according to your factory specs and adjust it from there. Let us know what it's doing, along the way, so we can offer you the right advise.
The carb might be your only problem, but just to be on the safe side, clean out your filter so nothing else reaches the needles.
Austin
RCNT Basher
Georgia
Bashing
Alright, So just fill the gas tank about half full with DA, let it sit for an hour, then do what?
Rolex
Hoof Hearted
Staff member
Military Veteran
In my recliner
Bashing, Flying
add a pretty good length of fuel line to the bottom connection and suck some DA through the stone, and blow it back into the tank. Just keep doing that till you know it's been rinsed out thoroughly. Don't get it in your mouth, and make sure you blow the last shot into the tank. If the DA actually LOOKS dirty, do it again.
Austin
RCNT Basher
Georgia
Bashing
alright, I'm ordering some new fuel line also so that should work out nicely, thanks =]
Tmaxx96
Gone - bye bye.
Willington,CT
Bashing, Racing
to get to the piston take the backplate off and look up into the engine but ony do that if the new carb doesn't work ok
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
I HELP! Hyper 7 TQ Engine Problems During Break-in Nitro RC 9
J Jato engine problems Engines 6
N Engine tuning problems Nitro RC 4
L Pullstart/Engine problems Nitro RC 5
Ant engine problems Nitro RC 2
N .32 Nitro Engine Over Heating Problems Need Help Asap Nitro RC 4
N hbx .21 engine problems Nitro RC 7
kalib engine problems Buggy and Truggy 3
M Nitro Boat Engine Problems Nitro RC 2
A Engine turns on but no more throttle response **Strike #2** (Gearbox problems) Nitro RC 4
laton7 engine fitting problems Nitro RC 14
Zdragon71 HPI f3.5 engine tuning problems Nitro RC 16
backlash92 kyosho gx-12 engine problems Nitro RC 1
A engine problems HPI Savage 0
B Weird engine problems? Nitro RC 16
R help needed new to rc nitro and having problems breaking in engine. Chassis & Drivetrain 4
N engine start problems Nitro RC 2
A Engine problems. Nitro RC 5
2 Engine problems Nitro RC 14
T Thunder Tiger 15 Engine Problems Chassis & Drivetrain 0
S set up problems over revving engine Nitro RC 5
fescue101 engine problems /stalls Nitro RC 2
O Ofna engine problems Buggy and Truggy 4
N Alpha S852 Engine problems. Nitro RC 12
N unresolved engine/tuning problems Nitro RC 13
T 3.3 engine problems please help!!new to rc Chassis & Drivetrain 3
C 2 RC Engine problems and fuel presuring Nitro RC 4
V engine problems??? Chassis & Drivetrain 2
Z T Maxx 3.3 engine starting problems??? Traxxas T-Maxx 5
R revo engine problems Traxxas Revo 1
P more trouble......engine/starter problems... HPI Savage 6
0 engine problems Buggy and Truggy 10
A Engine Problems Nitro RC 5
R t-maxx engine problems Chassis & Drivetrain 6
D Engine problems.... Team Losi LST 2
D 2.5 engine big problems Chassis & Drivetrain 10
M engine problems!!! HPI Savage 11
J Team Infinity 18 Pull Start Engine Problems? Nitro RC 3
J more problems with my engine?! Nitro RC 5
B possible engine or tranny problems..... Traxxas T-Maxx 4
D lst2 xxl engine problems Nitro RC 1
N Engine Problems Traxxas Revo 4
M Engine Reving/problems Team Losi LST 1
N engine problems Traxxas T-Maxx 3
B Savage XL engine problems? HPI Savage 5
I Could new exhaust be linked to engine problems???? Traxxas T-Maxx 13
B Engine Problems Nitro RC 22
K Engine Problems Nitro RC 24
O Engine problems?! Team Losi LST 21
O Engine problems?! Team Losi LST 0
