bubble27
Mini crt st .5
1:12
4WD
Hyper 12 Pullstart
Scale comparison with crt.5 st 1/8 scale
Length 364mm
Height 140mm
Width 285mm
Wheelbase 242~245mm
Weight 1960g
Gear Ratio 11.498:1
Ground Clearance 45mm
Engine 12~18 Class
DBX/DST
Even tho one looks like a buggy and the other like a truggy they the same size exactly. Only covers are different
1:10
4WD
Length 450mm
Width 326mm
Height 150mm
Wheelbase 299mm
Tread (F/R) 274mm
Tire(F/R) Φ110×56mm
Gear Ratio 10.9:1
Weight Approximately 2,300g (with body)
Engine GXR18 with recoil starter
Do these two cars compare in speed and handling? I think the kyosho might handle better cause of its size but is way slower!
Also on the 1/12th scale you can put a .18 OS engine!!
1:12
4WD
Hyper 12 Pullstart
Length 364mm
Height 140mm
Width 285mm
Wheelbase 242~245mm
Weight 1960g
Gear Ratio 11.498:1
Engine 12~18 Class
DBX/DST
1:10
4WD
Length 450mm
Width 326mm
Height 150mm
Wheelbase 299mm
Tread (F/R) 274mm
Tire(F/R) Φ110×56mm
Gear Ratio 10.9:1
