The Axial Yeti XL is a solid rear axle rock racer in a large scale RC size. Nearly the same size as a 1/5th scale HPI Baja 5B the Axial Yeti XL is a monster buggy! Powered by a Castle Creations 2200KV 4-pole brushless motor, water resistant electronics and a 2.4Ghz Tactic radio system.
Axial Yeti XL Manual
Axial Yeti XL Parts List
#AX24206 – 2.4GHz Radio System (2 Channel) (AX-3, AR-3)
#AX30163 – Pin 2.0x10mm (6pcs.)
#AX30165 – Pin 2.5x12mm (6pcs)
#AX30171 – Differential Cross Pin (2pcs)
#AX30386 – Differential Gasket 19.4×29.5×0.5mm (2pcs)
#AX31000 – XL 2 Speed Transmission Case
#AX31001 – XL 2 Speed Motor Mount
#AX31004 – Yeti XL Rear Shock Mount
#AX31005 – Yeti XL Chassis Cross Members
#AX31006 – Yeti XL Chassis Cage Components
#AX31007 – Yeti XL Chassis Rear Risers
#AX31008 – Yeti XL Rear Chassis Link Mounts (Upper and Lower)
#AX31010 – Y-480 Roll Cage (Passenger Side)
#AX31011 – Y-480 Roll Cage (Driver Side)
#AX31012 – Y-480 Roll Cage (Roof and Hood)
#AX31013 – Y-480 Roll Cage (Tire Carrier)
#AX31014 – Yeti XL Rear Links (Upper and Lower) (1pc)
#AX31015 – Yeti XL Rear Links Stiffeners (Upper and Lower (1pc)
#AX31016 – AR60 XL Rear Axle Truss and Differential Cover
#AX31017 – Yeti XL Steering Knuckle Set
#AX31018 – Yeti XL Lower Front Control Arm Set
#AX31019 – Yeti XL Steering Knuckle Carrier Set
#AX31020 – Yeti XL Battery Tray Door
#AX31021 – Yeti XL Electronics Box Parts
#AX31022 – Steering Bellcrank
#AX31023 – Yeti XL Transmission Spur Gear Cover
#AX31024 – Rod End Ball Set (6.8x8x3mm)
#AX31025 – Yeti XL Front Shock Tower
#AX31030 – Big Bore Shock Cap Parts (16mm)
#AX31031 – Big Bore Shock Parts and Piston (16mm)
#AX31032 – Big Bore Shock Parts and Rod Ends (16mm)
#AX31033 – Yeti XL Front Links (Upper Control and Steering)
#AX31034 – WB XL Driveshaft
#AX31035 – Yeti XL Body Mount Set
#AX31036 – Yeti XL Front Bumper Set
#AX31038 – Y-480 Front Interior Set – .040″ (Clear)
#AX31039 – Y-480 1/8th Scale Body – .040″ (Clear)
#AX31040 – Y-480 Helmet Set
#AX31041 – Differential Outdrive 11x30mm
#AX31042 – 3.8 BFGoodrich Krawler T/A Tires – R35 Compound (2pcs)
#AX31043 – 3.8 Raceline Monster Wheels (Black) (2pcs)
#AX31044 – AR60 XL Rear Axle Housing
#AX31045 – Screw Shaft M4x2.5x13mm (10pcs)
#AX31046 – Steering King Pin 14.7x4mm (Ti-Nitride Coated) (2pcs)
#AX31048 – Yeti XL Front Clip and Skid Plate
#AX31050 – Hinge Pin 4x85mm (Threaded) (Black) (6pcs)
#AX31051 – M4 Nylon Locking Hex Nut (Black) (10pcs)
#AX31052 – Yeti XL Front Bulkhead
#AX31053 – Machined Bevel Gear Set – 32T/11T
#AX31055 – Differential Case
#AX31056 – Differential Output Shaft (2pcs)
#AX31057 – Differential Gear Set – 20T/10T
#AX31059 – Slipper Plate Washer 33x1mm (2pcs)
#AX31062 – Yeti XL Main Chassis Tub
#AX31063 – Slipper Drive Gear Shaft 5x92mm
#AX31064 – Outdrive Shaft
#AX31067 – Slipper Plate (2pcs)
#AX31068 – Slipper Pad 32.8×15.2x1mm (2pcs)
#AX31069 – Metal Spur Gear 32P 68T
#AX31070 – Motor Plate
#AX31072 – Servo Saver Spring 2.2×11.8mm 230.51 lbs/in
#AX31073 – M3x4x15mm Hex Socket Button Head Shoulder Screw – Black (6pcs)
#AX31075 – O-Ring 15.5×1.5mm (S16) (6pcs)
#AX31076 – O-Ring 3.8×1.9mm (P4) (10pcs)
#AX31078 – Spring 23x109mm 4.52 lbs/in – (White) (2pcs)
#AX31079 – Rubber Bump Stop 4x8x4mm (6pcs)
#AX31080 – Big Bore Aluminum Shock Body 99-150mm (2pcs)
#AX31081 – Shock Shaft 4x83mm (2pcs)
#AX31082 – Transmission Output (Front and Rear)
#AX31083 – Radio Box Seals
#AX31084 – AR60 XL Straight Axle Adapter
#AX31085 – Rear Axle 10×169.5mm (2pcs)
#AX31087 – M5 Locking Wheel Washer 8x20x3mm (4pcs)
#AX31088 – Yeti XL Front Bumper Skid Plate Aluminum
#AX31089 – Center Universal Driveline 11x155mm
#AX31091 – AE-4 Vanguard XL ESC
#AX31092 – Vanguard XL 2200KV Brushless Motor
#AX31119 – M3x35mm Hex Socket Button Head (Black) (10pcs)
#AX31120 – M3x10mm Hex Socket Flat Head (Black) (10pcs)
#AX31121 – M4x12mm Cap Head (Black) (10pcs)
#AX31129 – 2-Speed Hi/Lo Transmission Bottom Shaft (5x75mm)
#AX31194 – M2.6x4mm Hex Socket Button Head (Black) (10pcs)
#AX31195 – M2.6x12mm Hex Socket Button Head (Black) (10pcs)
#AX31196 – Washer 4x10x0.15mm (10pcs)
#AX31197 – O-Ring 9.5×1.9mm (10pcs)
#AX31198 – Bearing 6x10x3mm (2pcs)
#AX31200 – Bearing 6x12x4mm (2pcs)
#AX31201 – Bearing 10x16x4mm (2pcs)
#AX31202 – M3x45mm Hex Socket Button Head (Black) (6pcs)
#AX31204 – M3x6mm Set Screw (Black) (10pcs)
#AX31205 – M2.6x8mm Hex Socket Tapping Button Head (Black) (10pcs)
#AX31206 – M3x45mm Hex Socket Flat Head (Black) (6pcs)
#AX31207 – Y-480 Rear Interior and Number Plates Set – .040″ (Clear)
#AX31212 – Pinion Gear 32P 15T – Steel (5mm Motor Shaft)
#AX31220 – Universal Joint Axle Shaft 15.5x38mm (2pcs)
#AX31221 – WB XL Driveshaft Coupler
#AX31222 – Universal Joint Rebuild Kit (2pcs)
#AX31223 – Pin 2.5×14.5mm (6pcs)
#AX31224 – C-Clip 14.3mm (10pcs)
#AX31225 – Universal Joint Dogbone 123mm (2pcs)
#AX31226 – 32P 19T Transmission Gear
#AX31227 – 32P 18T Transmission Gear
#AX31228 – 32P 34T Transmission Gear
#AX31230 – 17mm Aluminum Hub – Black (4pcs)
#AX31231 – 8mm Body Clips (Black) (10pcs)
#AX31232 – Screw Shaft M4x2.5×16.5mm (6pcs)
#AX31233 – Washer 6x19x0.2mm (Black) (6pcs)
#AX31234 – Battery Tray Foam Pad Set
#AX31235 – Slipper Spring 10x7mm 228lbs/in (Black) (2pcs)
#AX31236 – Front Aluminum Skid Plate
#AX31237 – Front Aluminum Upper Brace
#AX31238 – M3x50mm Cap Head (Black) (6pcs)
#AX80006 – Servo Set
#AXA0109 – M3x10mm Oversized Flat Hex Socket (Black) (10pcs)
#AXA0113 – M3x6mm Hex Socket Button Head (Black) (10pcs)
#AXA0147 – M3x16mm Hex Socket Flat Head (Black) (10pcs)
#AXA0151 – M3x30mm Hex Socket Flat Head (Black) (10pcs)
#AXA0187 – M3x20mm Set Screw (Black) (10pcs)
#AXA0414 – M2.6x10mm Hex Socket Tapping Flat Head (Black) (10pcs)
#AXA0422 – M2.6x6mm Hex Socket Tapping Button Head (Black) (10pcs)
#AXA0437 – M3x15mm Hex Socket Tapping Button Head (Black) (10pcs)
#AXA0439 – M3x20mm Hex Socket Tapping Button Head (Black) (10pcs)
#AXA089 – M3x25mm Cap Head (Black) (10pcs)
#AXA1041 – M2.5 Nylon Locking Hex Nut – Silver (10pcs)
#AXA1045 – M4 Nylon Lock Nut (Black) (10pcs)
#AXA1052 – M3 Thin Nylon Locking Hex Nut (Black)
#AXA1053 – M3 Nylon Locking Hex Nut (Black) (10pcs)
#AXA1059 – 6mm Body clip (Black) (10pcs)
#AXA1069 – Washer 2.7×6.7×0.5 (10pcs)
#AXA1071 – Washer 4x8x0.5mm (10pcs)
#AXA1072 – Washer 3x8x0.5mm
#AXA114 – M3x8mm Hex Socket Button Head (Black) (10pcs)
#AXA115 – M3x10mm Hex Socket Button Head (Black) (10pcs)
#AXA116 – M3x12mm Hex Socket Button Head – Black (10pcs)
#AXA117 – M3x15mm Hex Socket Button Head (Black) (10pcs)
#AXA118 – M3x18mm Hex Socket Button Head – Black (10pcs)
#AXA119 – M3x20mm Hex Socket Button Head (Black) (10pcs)
#AXA121 – M3x30mm Hex Socket Button Head (Black) (10pcs)
#AXA1221 – Bearing 5x11x4mm (2pcs)
#AXA1225 – Bearing 8x16x5mm (2pcs)
#AXA1243 – Bearing 15x21x4mm (2pcs)
#AXA146 – M3x12mm Hex Socket Flat Head – Black (10pcs)
#AXA148 – M3x18mm Hex Socket Flat Head (Black) (10pcs)
#AXA149 – M3x20mm Hex Socket Flat Head – Black (10pcs)
#AXA291 – M4x4mm Set Screw (Black) (6pcs.)
#AXA433 – M3x6mm Hex Socket Tapping Button Head – Black (10pcs)
#AXA434 – M3x8mm Hex Socket Tapping Button Head (Black) (10pcs)
#AXA435 – M3x10mm Hex Socket Tapping Button Head (Black) (10pcs)
