Axial Wraith Manual and Parts List
Axial Wraith RTR
The Axial Wraith is a full tube frame chassis R/C rock racer, built not only to crawl over rocks but to go FAST!
Axial Wraith Manual
Axial Wraith Parts List
#AX12015 – 2.2 Ripsaw Tires – R35 Compound (2pcs)
#AX30031 – Antenna
#AX30041 – Velcro Strap 15x160mm
#AX30112 – Shock Diaphragm 13×4.5mm (6pcs)
#AX30113 – Rubber Bump Stop 3.6x7x4 (6pcs)
#AX30155 – Shock Shaft 3×59.5 (2pcs)
#AX30162 – Pin 1.5x8mm(6pcs.)
#AX30163 – Pin 2.0x10mm (6pcs.)
#AX30166 – Pin 1.5x11mm(6pcs)
#AX30190 – Shaft 5×18 (2pcs.)
#AX30198 – Slipper DriveGear Shaft 5×53.5
#AX30218 – Spring14x70mm 2.07 lbs/in- Super Soft (Red) (2pcs)
#AX30368 – Axle6x39mm (2pcs)
#AX30385 – Diff Gasket 16x25x0.5mm(2pcs)
#AX30392 – Bevel Gear Set (38/13)
#AX30394 – 20T Drive Gear
#AX30408 – Input Shaft 5x29mm (2pcs)
#AX30410 – Inner Slipper Plate
#AX30411 – Outer Slipper Plate
#AX30412 – Slipper pad 27x8x1mm
#AX30413 – Slipper spring 8.5×12 165 lbs/in- Black(2pcs)
#AX30419 – AR60OCP Front Dogbone Set (2pcs)
#AX30429 – 12mmAluminum Hub(Black) (4pcs)
#AX30435 – Steel OutdriveShaft Set (2pcs)
#AX30437 – DigLockout Shaft
#AX30450 – Flange Pipe 3×4.5×5.5 (4pcs)
#AX30463 – WB8 Universal Joint Rebuild Kit (2pcs)
#AX30491 – AX10RTR Motor Plate
#AX30500 – HeavyDutyLocker(2pcs)
#AX30578 – Pinion 48DP 20 T
#AX30665 – Spur48DP80T
#AX30776 – AR60OCP Rear AxleSet (2pcs)
#AX30777 – 56x17mm Servo Plate
#AX30778 – Zero Ackerman Steering Plate (2pcs)
#AX30784 – WB8DriveshaftCoupler Set
#AX4027 – WraithBody-.040″ (Clear)
#AX4028 – Wraith InteriorSet – .040″ (Clear)
#AX80002 – Diff Case-Small
#AX80006 – Servo Set
#AX80010 – Gear Set
#AX80018 – Hardware Parts Tree
#AX80033 – 10mm Shock Parts Tree 1
#AX80034 – 10mm Shock Parts Tree 2
#AX80035 – 10mm Shock Caps Parts Tree
#AX80036 – 72-103mm Shock Body
#AX80037 – Interior Details Parts Tree – Black
#AX80045 – LED Light HolderSet A
#AX80049 – LED Lens Set-Clear
#AX80051 – DigTransmission Case
#AX80061 – XR10Steering Knuckles Set
#AX80062 – XR10C Hub Carrier Set
#AX80069 – AR60 OCP Axle Housing
#AX80070 – AR60 OCP Differential Cover
#AX80071 – AR60OCP StraightAxleAdapter
#AX80072 – AR60 OCP 4-Link Mount
#AX80073 – AR60OCP Steering Link
#AX80074 – Wraith Tube Frame Rails
#AX80075 – Wraith Tube Frame Top
#AX80076 – WraithTube Frame Shock Mount(Rear)
#AX80077 – Wraith Tube Frame Bumper
#AX80078 – Transmission Spur Gear Cover
#AX80079 – WraithTube Frame Skid Plate/Battery Tray
#AX80080 – Corbeau LG1 Seat (Grey)(2pcs)
#AX80081 – Wraith Tube Frame Electronics Box
#AX80082 – Wraith Tube Frame Brace Set
#AX80083 – Wraith Links Set
#AX80084 – WB8 Driveshaft
#AX80087 – WraithTube Frame Side (Left)
#AX80088 – WraithTube Frame Side (Right)
#AX80089 – WraithTube Frame Shock Mount(Front)
#AX08137 – 2.2 Raceline Renegade Wheels – 41mmWide (Chrome) (2pcs)
#AXA013 – M2x6mm Cap Head (BlackOxide)
#AXA1243 – Bearing 15x21x4mm
#AXA015 – M2x10mmCap Head
#AXA083 – M3x6mm Cap Head (Black)
#AXA087 – M3x16mm Cap Head (Black)
#AXA089 – M3x25mmCap Head (Black)
#AXA091 – M3x30mm Cap Head (Black)
#AXA0109 – M3x10mm Oversized Flat Hex Socket
#AXA1040 – M3THINHEX NUT(BLACK)
#AXA1041 – Nylon Locknut2.5
#AXA1045 – M4Nylon LockNut(Black)
#AXA1052 – M3Thin Nylon Locking Hex Nut(BLACK)
#AXA1053 – M3NylonLocking Hex Nut (BLACK)
#AXA1069 – WASHER 2.7×6.7×0.5
#AXA1070 – WASHER 3x6x0.5
#AXA1071 – Washer 4x8x1mm
#AXA1091 – WASHER 3x6x0.5
#AXA0113 – M3x6mm Hex Socket Button Head (Black)(1Opes)
#AXA115 – M3x10mm HexSocket ButtonHead (Black) (1Opes)
#AXA116 – M3x12mm Hex Socket ButtonHead (Black)
#AXA117 – M3x15mm Hex Socket ButtonHead (Black)
#AXA118 – M3x18mm HexSocket ButtonHead (Black)
#AXA1184 – O-Ring7.5×1.5mm(S8)
#AXA1202 – O-Ring 3.5x2mm
#AXA1393 – E2.5e-clip(10pcs)
#AXA144 – M3x8mm Hex Socket Flat Head (Black)
#AXA180 – M3x3mm Set Screw (Black)
#AXA0187 – M3x20mm Set Screw (BlackOxide)
#AXA0412 – M2.6x6mm Hex Socket Tapping Flat Head (Black)
#AXA0413 – M2.6x8mm HexSocket TappingFlatHead (Black) (1Opes)
#AXA0414 – M2.6x10mm Hex Socket Tapping Flat Head (Black)
#AXA0416 – M2.6x18mm HexSocket Tapping Flat Head (Black) (10pcs)
#AXA0422 – M2.6x6mm Hex Socket Tapping ButtonHead (Black) (1Opes)
#AXA433 – M3x6mm Hex Socket Tapping Button Head (Black)
#AXA434 – M3x8mm Hex Socket Tapping Button Head (Black)
#AXA435 – M3x10mmHex Socket Tapping Button Head (Black)
#AXA436 – M3x12mm Hex Socket Tapping ButtonHead (Black)
#AXA0437 – M3x15mm Hex Socket Tapping ButtonHead (Black)
#AXA438 – M3x18mm HexSocket Tapping ButtonHead (Black)
#AXA0439 – M3x20mm HexSocket Tapping ButtonHead (Black) (10pcs)
#AXA440 – M3x25mm HexSocket Tapping Button Head (Black)
#AXA441 – M3x30mm Hex Socket Tapping ButtonHead (Black)
#AXA463 – M3x6mm Hex Socket Tapping Flat Head (Black)
#AXA464 – M3x8mm Hex Socket Tapping Flat Head (Black)
#AXA465 – M3x10mm Hex Socket Tapping Flat Head (Black)
#AXA466 – M3x12mm Hex Socket Tapping Flat Head (Black)
#AXA1090 – Washer 4.8×14 (Green)
#AXA1356 – SiliconeShock Bushing7.5x8mm(6pcs)
#AXA0175 – Screw Shaft M3x2.5x11mm(1Opes)
#AXA1218 – Bearing5x10x4mm
#AXA1221 – Bearing 5x11x4mm
#AXA1225 – Bearing 8x16x5mm
#AXA1230 – Bearing 10x15x4mm
#AX24003 – Axial 20T Electric Motor
#AX24204 – Axial 2.4Ghz Radio System (2-Channel)
#AX24253 – Axial Double LED LightString (Red LED)
#AX24257 – Simple LED Controllerw/LED lights(4 whiteand 2 Red)
#AX24258 – 4 LED String (WhiteLED)
#AX24259 – Axial AE-2Forward/ReverseESCw/Drag Brake
Axial Wraith Videos
